Need BCM but cannot find one
Old Jun 25, 2024 | 01:08 PM
Therealfischy's Avatar
My shop told me I need a new bcm because my headlights are not working but they can't get the part and from what I've checked they're all out of stock online. Anyone delt with this? I'm in Alaska as well.
06 hhr ls
Old Jun 25, 2024 | 01:48 PM
Many other possibilities as to the head lights not working, fuses relays , ground wires burnt bulb sockets
Welcome to the site.
Doubtful the BCM is the cause.
https://fuse-box.info/chevrolet/chev...uses-and-relay
Old Jun 25, 2024 | 02:07 PM
Could be the control multifunction "stalk".
Old Jun 25, 2024 | 02:26 PM
I guess your lazy shop doesn't know about GoOgle. Get a written money back guaranty that it will fix the problem,. It takes doing something to break the BCM, highly unlikely it is the problem.
I would not bother with a new one. They do need to be programmed new or used. There are services on Ebay that can program for you. You will need to do a key relearn.
Old Jun 25, 2024 | 03:56 PM
Could be the old 4 bolts in the under hood fuse box need to be tightened!
These four 7 mm boots !
Old Jun 25, 2024 | 05:18 PM
I tried the fuses and relays with no luck.
Old Jun 25, 2024 | 05:20 PM
Like this? I tried a new one didn't fix it .
http://https://a.co/d/0gZaAoH9
Old Jun 25, 2024 | 05:21 PM
I'll take a look at that today and get back to you.
Old Jun 25, 2024 | 05:23 PM
looks like the car was in an accident at some point it has an unpainted bumper. I found a company online that will ship me one. I just payed the shop for the diagnostic, they wanted around 600$ to replace it!
Old Jun 25, 2024 | 07:47 PM
PulpFriction's Avatar
For the BCM to be responsible for no headlights, with no other issues, seems odd.
Because the bumper was replaced, there's a chance something got miswired. You need to chech for voltage at the headlight fuse pins.
Does the car have LED headlights, by any chance?
