Need Help
Old Nov 19, 2017 | 07:29 PM
teraflack's Avatar
Need Help
2007 HHR is still making noise in front end after replacing both front and back brakes, both struts, rear shocks and swaybar links in front
Old Nov 19, 2017 | 07:33 PM
Hi teraflack, to the forums!!
Here is our thread on diagnosing and fixing front end noises.
https://www.chevyhhr.net/forums/prob...g-pop-s-50648/
Old Nov 19, 2017 | 08:13 PM
But, for some reason you didn't look at the lower control arm bushings.
If you would give more information about the noise we might be able to offer more help.
When,where,description etc.
Old Nov 19, 2017 | 10:01 PM
Welcome to the site, don’t forget the sway bar bushings , upper engine mount and the rear lower control arm bolts not torqued correctly
Most likely the bushings themselves are toast
Old Nov 20, 2017 | 08:32 AM
aradmahogany's Avatar
A new One I found was if you get a knock/clunk when coming to a stop with the wheel turned it could be worn tie rods/ a worn steering rack. I had that before replacing the rack and now its tight and silent. But, My guess is you have the noise as a result of lower control arm bushings.
SpaceCowboy
Jan 27, 2012 02:28 PM
gotboost
11
Jan 20, 2012 07:30 PM
jgoldwood
Mar 8, 2011 07:45 PM
carajean
Tires & Wheels
11
Dec 8, 2010 06:06 PM
NEXTIMAGE
Feb 8, 2008 04:26 AM
