need help with p2122 code
Old Nov 30, 2017 | 08:42 AM
Both are in the pedal assembly. One for how far down and one for how far up.
Old Nov 30, 2017 | 09:08 AM
The sensors are in the foot pedal, look for loose wires in the harness connections and give the throttle body a proper cleaning, with the correct TB spray cleaner, remember do not move the butterfly manually, you might strip the plastic gears in it!
I simply remove the air filter assembly, then unbolt the throttle body lift it up and turn it 90 degrees, and give it a spray of this.
And this in the throttle pedal connections
Old Dec 5, 2017 | 05:32 PM
Blue_SS's Avatar
This DTC is almost always a wiring/connection issue. Many people can just unplug and replug and fix it forever.
Agpullen
Feb 6, 2016 05:53 PM
DASH0071972@
23
Jul 1, 2015 12:31 PM
edgarfrog
Oct 25, 2013 08:43 AM
LtGhost08
Jun 10, 2013 02:13 PM
tkfross
Oct 25, 2012 08:55 AM
