New motor questions
Old Oct 26, 2023 | 04:04 PM
fastsuv's Avatar
This brings back memories of fabricating a shaft with a flat on the end to fit down the distributor hole (distributor removed first of course) to spin the oil pump with a drill on a small block V8 after a rebuild.
Steve
Old Oct 26, 2023 | 04:05 PM
fastsuv's Avatar
Forgot to mention, using assembly lube on cam lobes first.
Steve
Old Oct 30, 2023 | 05:24 PM
Blownfuel's Avatar
I just did a new GM long block in mine. Changed the oil immediately after the break in procedure in case there was any dirt / trash in the engine (also, the break in lube "can" plug up an oil filter if used excessively), and changed it again yesterday at 1000 miles. I also used convetional oil for the first two break in runs to help with seating rings, then swithed to full synthetic yesterday.
Kurt
Old Oct 30, 2023 | 05:27 PM
Blownfuel's Avatar
Never had much luck with those priming tools until I took an old HEI and turned the teeth off the dist. gear and turned the upper body down about 1.5" smaller diameter for clearance on certain engines. Worked like a champ!
m_ridzon
Nov 1, 2021 10:40 AM
hurst2001
Maintenance and Upkeep
Feb 8, 2020 02:32 PM
Dementors1
2.0L Performance Tech
12
Sep 26, 2015 12:45 PM
sn3ak
Aug 12, 2012 11:28 AM
reagle
Nov 17, 2008 06:48 AM
