No bi-level or defrost
Old Oct 27, 2012 | 02:34 PM
blacky's Avatar
No bi-level or defrost. Floor ok. Heat, AC, blower speeds otherwise fine.
Assume blue vacuum module mounted under hood, passenger side, near fender.
Comments welcome for head start before heading out to repair in wet weather.
Old Oct 27, 2012 | 03:52 PM
Are you talking about an HHR? A) mine has no blue vacuum module B) the HVAC control doors are electronic, not vacuum.
Old Jun 27, 2013 | 07:55 PM
jpplumbing's Avatar
sorry to bring this thread up from the grave but i am having the same issue. Mine works from defrost to floor both heat and a/c but nothing in the middle vents. The window vents do work (the small non adj. ones) I have a 07 lt
Old Jun 27, 2013 | 10:58 PM
No need to apologize for bringing a thread back from the great beyond, it sounds like you either have stuck blend doors or a broken actuator.
Give this thread a read.....
https://www.chevyhhr.net/forums/problems-service-repairs-42/heater-problem-33767/
P.S. to the forum!
Old Jun 30, 2013 | 02:49 PM
Sounds more like "mode" switch or door than "temp".
HillsdaleHHR
Oct 14, 2019 12:09 AM
ardblo
Sep 20, 2013 02:03 PM
ryanflynt
Apr 2, 2010 02:14 PM
BobW55
Mar 14, 2010 10:05 AM
xzombiex66
Nov 18, 2009 06:05 AM
