No chime when door is opened with key still in ignition, cylinder or switch? Both?
Old Apr 17, 2023 | 08:35 PM
Kokomo's Avatar
Ok I bought a tech 2 scanner and it has a B1380 code and it shows Ignition Switch Fault = Yes under the remote start disable history. This tool is awesome I also used it to program a spare new fob I had.
I’ll take another good look to make sure no wires are gouged missing from the PO’s stereo install and if not I’ll source and replace the switch. I shouldn’t have to replace the cylinder too do I? I’m not sure if it provides a ground signal or something when the key is inserted.
Old Apr 17, 2023 | 09:40 PM
You said it was factory stereo. If the PO tried to install without a GMLan module he probably tried to steal a signal from some silly spot. Which is why I asked about it.
B1380 pertains to the ACC circuit. 01 is a short to BAT. 02 is short to ground.
Old Apr 17, 2023 | 10:36 PM
Kokomo's Avatar
That’s gotta be what that blue wire was!! Yes it definitely had an amp/stereo but it was removed and replaced with the factory stereo before it got sold. I never mentioned that I apologize
Now that I think of it the solenoid that releases the key also doesn’t work it’s surely related
Old Apr 18, 2023 | 08:37 AM
Here are the color codes out of the ignition switch and the key lock
Allen P
Jul 12, 2021 05:49 AM
hhr11
Feb 23, 2020 02:27 PM
WoodysMobile
Sep 6, 2019 03:44 PM
DrTrapper
GM Recall Campaigns
23
Apr 10, 2014 12:27 AM
alexrckid
GM Recall Campaigns
Apr 9, 2014 09:21 PM
