no crank, no start 08 HHR
Old Jan 14, 2015 | 04:28 PM
Marush's Avatar
Angry Throwing code P0480
08 hhr. ???
Old Jan 14, 2015 | 04:30 PM
RatRodS's Avatar
Did a search on here and found this
https://www.chevyhhr.net/forums/prob...010-hhr-14259/
Old Jan 14, 2015 | 04:32 PM
RatRodS's Avatar
P0480 Chevrolet Cooling Fan Relay Control Circuit OBDII Engine Light Trouble Code | Engine-Codes.com
Old Jan 14, 2015 | 05:36 PM
You have this code P0480 issue posted in 3 different threads. You really should just have it posted in the original thread you started regarding the "no start".
No sense in causing confusion by having it posted in multiple places.
Maybe our Mods can combine them together.
Old Jan 14, 2015 | 06:36 PM
The thread posted in the how to forum has been deleted because it was just in the wrong section. The other thread has been merged into this one.
The very first thing anybody should do after they get a code number is to Google it. After reading a few links then come back to Chevyhhr.net and put it into the search box.
Just looking at the title of RatRodSs link, I am guessing the fuse and/or the relay for the cooling fan was damaged. Could also be what my very first thought was: a spark was shot at the ECM. Or, one of the ground straps got fried.
Old Jan 14, 2015 | 07:47 PM
  #26
P0480 relates to the cooling fan relay, possible fuse blown, damaged relay or the easy and least expensive loose ground connection.
Type P0480 into the search widow there is a thread there for your hubby to read thru and check. This code may clear after the battery is disconnected for 30 minutes, to clear and reset the codes, but it may reappear in time
Old Jan 16, 2015 | 12:23 AM
  #27
Merged - please keep related postings in the same thread - ie: the p0480 codes in this thread and the block heater power cord threads.
mamasmad
Jul 28, 2014 05:34 PM
Snoopy
Jan 18, 2014 10:31 PM
jm9678
Jan 10, 2014 06:22 PM
springer.83
Dec 29, 2013 10:59 AM
rendon47
Dec 26, 2013 07:00 PM
