No crank problem
Old Aug 16, 2022 | 12:06 AM
B_Radbean1981's Avatar
I thought I had sent a response to the fuse box not being completely tightened as the culprit, but I don't see it here. After tightening them all down, started right up... With a jump of course lol. Thanks for y'alls help!! On a side note is there something that would cause me to not get my clutch completely bled? Stated before that I changed the slave with the clutch and the master right after. But it seems no matter how many times I try to bleed the air out, the pedal is still spongy...😡😡
Old Aug 16, 2022 | 01:41 PM
Have you looked at the firewall? It has been known to crack around the clutch MC.
Old Aug 16, 2022 | 02:46 PM
Originally Posted by B_Radbean1981
It was the fuse box. I had a suspicion that was it after reading your post about tightening it and thinking it was tight. The first one I tightened I felt it pop and was worried I had broken it. Thanks for the help guys!!
you mean this post^^^^^^
Old Aug 16, 2022 | 03:11 PM
Yes, I hadn't noticed that the site computers had sent it to moderation purgatory. I just noticed, and approved it, today.
Old Aug 17, 2022 | 12:50 PM
Yes!!! For some reason it wasn't there the other evening!!
Old Aug 17, 2022 | 12:52 PM
I'm confused the firewall is known to crack?🤣🤣 Or the MC??
Old Aug 17, 2022 | 01:35 PM
Firewall
Some photos in this thread
https://www.chevyhhr.net/forums/driv...-issues-62780/
Old Aug 17, 2022 | 02:18 PM
Firewall is the subject, the MC is the vicinity. How could that statement possibly be interpreted as the MC cracking?
Old Aug 17, 2022 | 05:18 PM
It might have been MC Hammered!
Hammer time!
can’t touch this!
Old Aug 20, 2022 | 10:39 AM
So I am about to pull the fuse box again to check for the failed firewall. I weaseled my hand in there and it seems a bit loose although I couldn't see any noticeable movement when depressing the clutch. I would think you should see the MC moving out of place if the firewall was the problem yeah?
