No crank problem
Old Aug 20, 2022 | 11:00 AM
Perhaps there is a leak. Have you checked the fluid level? Although if fluid leaks out and is replaced with air, the level at the master cylinder might not change noticeably. Could be a damaged O-ring on the hose.
Old Aug 22, 2022 | 10:44 PM
B_Radbean1981's Avatar
Okay so I removed the fuse box....again.... Love me some engineers.... anyhow, it's not loose at the firewall and I see no visible leaks anywhere. I'm at a loss. But ATM this is our only vehicle and we can't keep driving it grinding gears as it is. I'm gonna try to bleed it one more time and check the trans fluid level again and just double check everything, connections and all....hopefully I find something....
Old Aug 22, 2022 | 10:47 PM
And a damaged o-ring is a possibility I suppose. The question is which one lol?? If I come up with nothing from my other checks I guess I'll revert to taking it back apart n check all the o-rings also.
Old Aug 23, 2022 | 08:01 AM
Might the shift linkage be going bad?
Old Aug 23, 2022 | 01:56 PM
He said the clutch pedal is spongy. Could be an internal leak in the master cylinder.
BigBossDaddy
Oct 24, 2020 05:08 PM
petvetdoc1
Aug 25, 2017 10:33 AM
Paquinr89
Jul 6, 2016 04:47 PM
sgmartin6
Jul 22, 2013 08:07 PM
raj49
Nov 27, 2012 02:41 PM
