No crank problem
Perhaps there is a leak. Have you checked the fluid level? Although if fluid leaks out and is replaced with air, the level at the master cylinder might not change noticeably. Could be a damaged O-ring on the hose.
Okay so I removed the fuse box....again.... Love me some engineers.... anyhow, it's not loose at the firewall and I see no visible leaks anywhere. I'm at a loss. But ATM this is our only vehicle and we can't keep driving it grinding gears as it is. I'm gonna try to bleed it one more time and check the trans fluid level again and just double check everything, connections and all....hopefully I find something....
