No crank problem
I thought I had sent a response to the fuse box not being completely tightened as the culprit, but I don't see it here. After tightening them all down, started right up... With a jump of course lol. Thanks for y'alls help!! On a side note is there something that would cause me to not get my clutch completely bled? Stated before that I changed the slave with the clutch and the master right after. But it seems no matter how many times I try to bleed the air out, the pedal is still spongy...😡😡
So I am about to pull the fuse box again to check for the failed firewall. I weaseled my hand in there and it seems a bit loose although I couldn't see any noticeable movement when depressing the clutch. I would think you should see the MC moving out of place if the firewall was the problem yeah?
