No power steering, taillights, windshield wipers
Old Dec 18, 2019 | 03:25 PM
bandit88's Avatar
Yes, this HHR, just not with an amplifier or this stereo
Old Dec 18, 2019 | 04:04 PM
Old Dec 18, 2019 | 04:21 PM
That's why I asked earlier. There is a different harness for "with Pioneer".
Old Dec 20, 2019 | 11:58 AM
bandit88's Avatar
Ok, I'll go back to the factory radio and go from there
Old Dec 20, 2019 | 06:58 PM
bandit88's Avatar
So I put the factory radio back in and didn't change anything. When you talk about the LAN, what is that and is there a way i can bypass the harness to check for the short? I'm learning as i go with this
Old Dec 29, 2019 | 06:17 PM
  #26
guppy's Avatar
Replace fuse 62
(I/P IGN, 20A)
Old Dec 31, 2019 | 03:45 PM
  #27
bandit88's Avatar
It had blown since I had checked it so now I have tail lights, heater controls and wipers but still don't have power steering, horn or cruise control. I checked every fuse for continuity and all are good I have relays out of the wrecked truck, should I switch them out?
Old Dec 31, 2019 | 05:43 PM
  #28
guppy's Avatar
Let's work on "ONE" thing at a time.
I pick HORN
Horn fuse is at location 60
Horn Relay is at location 55
Report back
Old Dec 31, 2019 | 05:47 PM
  #29
guppy's Avatar
POWER STEERING
Check the yellow 60 amp fuse at the top left of the fuse box. It will be very hard to pull, take your time so you dont break it. It is about $5 at the parts house!
Old Jan 2, 2020 | 06:31 PM
  #30
bandit88's Avatar
Ok, got a new fuse in the power steering and I'm getting a "Power Steering" code in the dash display.
I changed the relay on the horn and now it works with the key fob but not with the steering wheel and it did before.
