No tail light, no radio button, no heater control light
Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
I just got the car from auction. It went thru inspection fine, just did it all of a sudden the other night. I did relace the relay with another I had. I dosn't click like the headlight relay does when you turn it on.
Reason: spelling
Thanks for the diagram, that helps. SOOOO sould I be looking for a break in the wire somewhere. No that wouldn't be the cause because they will work at first for about 5 sec, then go off.
