Noise?
Old Jul 17, 2019 | 09:55 PM
Silverfox's Avatar
Oil ??
Yes ... check it immediately just too make sure, but Why the noise only at Idle ??
Silverfox
Old Jul 17, 2019 | 11:01 PM
Originally Posted by donbrew
With youtube you only need to paste the url into the post. Either by copying the address in the address bar or by Right click on the vid and choosing "copy video url" Then pasting.
That's what he had done, didn't work. I cut the url, and pasted it in the box in the "chain link", and it shows up.
Old Jul 18, 2019 | 08:24 AM
That is odd.
Old Jul 18, 2019 | 10:22 AM
Doc brown's Avatar
Yikes! I agree about checking the oil. That sounds like the valve train. At a minimum change the oil and use synthetic.
Years back I had a '99 Cadillac Catera. I was using Fram oil filters at the time. One day it started to make noise just like this. I decided I didn't want to deal with it and ended up giving the car to my dad. He took it apart and found pieces of the oil filter in small orifices leading to the valve train. Took the filter off and it was twisted up and broken apart. Amazingly he got everything working again but it always made noise for while after starting it up until everything got fully lubricated.
Old Jul 18, 2019 | 11:31 AM
Originally Posted by Silverfox
Oil ??
Silverfox
I was focused on fixing the video link, I missed that part about only at idle. Listening again, it does sound more like crankcase/valve sounds.
Old Jul 18, 2019 | 12:26 PM
cjsharkie's Avatar
There is oil, it is not leaking. Also there is around 115,000 miles on it. Ill do some investigating tonight and see what else might be wrong.
Old Jul 18, 2019 | 02:08 PM
Pull the valve cover, look at the front timing chain guide, and the top guide , is the chain loose
Old Jul 19, 2019 | 07:48 AM
aradmahogany's Avatar
that doesn't sound internal. sounds external, something like the airbox or the exhaust leak like others suggested.
Old Jul 19, 2019 | 09:39 AM
Only at idle, maybe because other sounds cover it up?
Old Jul 19, 2019 | 09:29 PM
Well @ 115K miles on the oil, time for a change.. Sorry couldn't resist... Hope it is something very minor.
adamlowery
Mar 14, 2014 02:21 AM
Gsus
Sep 6, 2013 08:42 AM
whopper
May 12, 2011 01:55 PM
HHR321
Feb 17, 2007 11:18 AM
HHR2006
Nov 11, 2006 05:31 AM
