Noise in rear wheel after new brake job
Old Dec 24, 2015 | 03:13 PM
hhr06NJ's Avatar
I just had brake shoes and drums replaced.
AFTER: I had clicking/knocking noise when medium pressure applied to brake
only left rear wheel.
The shop replaced the new drums
still clicking/knocking.
It is with the rotation of the wheel-as you slow, it slows too
Any ideas?
Old Dec 24, 2015 | 04:07 PM
Chances are the new drum on that side is slightly out of round, so it's catching on the brakes shoes then releasing them, hence the clicking/knocking sound.
It'll happen sometimes, take it back after Christmas, and most likely they'll either use a brake lathe to "true up" the drum, or they'll just swap it out for another one.
Annoying yes, dangerous not so much, will it drive you crazy for a couple of days..yup.
Old Dec 24, 2015 | 04:43 PM
hhr06NJ's Avatar
That is what they said, so they replaced both NEW drums. Do you think the replacements (2nd set) are out of round too? Do you think the who(le) batch is bad?
also they said they torque the lug nuts. And they did the 1st time, but today that air gun when went full blast right to it's stop. are those air guns set for low torque?
I didnt SEE him torque today, but may have missed it.
Old Dec 24, 2015 | 04:55 PM
Back in my "turning wrenches for a living" days, I would always check new drums and rotors before installing them.
I would put the new ones on the brake lathe to check them. Many, many times I would have to run a thin cut on them to true them up.
If they were obviously way out, I would just get another and return the defective one.
Old Dec 24, 2015 | 05:50 PM
Anybody suggest a bad rear hub/bearing?
Old Dec 24, 2015 | 05:51 PM
Hope you get them to fix it!!
Old Dec 26, 2015 | 01:32 PM
hhr06NJ's Avatar
Yes, I thought of a bearing, but they are usually all the time, and i had no noise until the brake job.
i will let you know...
camaro98z28
75
Feb 13, 2011 08:45 PM
robotworkshop
25
Jun 18, 2010 06:40 PM
Big Kahuna
Aug 17, 2009 07:41 AM
HHR_SS_QC
May 6, 2009 10:38 AM
Sunrise HHR
Oct 1, 2008 03:42 PM
