non-limp mode check engine light
Old Jul 11, 2011 | 06:01 PM
  #51
x2.....
Old Jul 11, 2011 | 06:04 PM
  #52
then where is the thermostat located??
Man, read back thru these posts - there are links posted to the procedure. I posted it. There is only so much we can do man to help you. I'd suggest you take it to a dealer. I'm done.
Old Jul 11, 2011 | 06:08 PM
  #53
Just below and to the right of the oil filter, at the end of the radiator hose.
Old Jul 11, 2011 | 06:15 PM
  #54
LawDog88's Avatar
Whopper, only so much I can do from an Android. plus I can't spend too much time searching as im a work..
Old Jul 11, 2011 | 06:16 PM
  #55
LawDog88's Avatar
thank you donbrew
Old Jul 11, 2011 | 07:12 PM
  #56
Old Jul 11, 2011 | 08:47 PM
  #57
LawDog88's Avatar
greybeard you crack me up.
Old Jul 17, 2011 | 02:10 PM
  #58
LawDog88's Avatar
Spoke with a friend who is a GM Service tech. He said that he thinks my problem is a faulty ECT sensor.. Concurrence?
Old Jul 17, 2011 | 03:19 PM
  #59
Seeing as the thermostat is a common failure on the HHR and the ECT sensor is not a common failure........ Hmmmmm
Obviously it must be the ECT sensor........
Now, seeing as this thread is quite old, and you were seriously low on coolant.... Ummmmm, did you ever figure out where it went???? Neighbor's kids with a siphon hose? Aliens? Alien kids with a siphon hose? Nevermind, You filled the tank (hopefully you keep your eye on the level now, right?) and had the code cleared, has the situation come back?
Troubleshooting 101.......
IF NOT...... The problem is one of leakage and you need to track that down.
IF SO....... It's more than likely thermostat, outside possibility of the failed sensor
Here, I've got an idea. Why not take it to a shop and have it fixed. Changing either of these parts or any other parts in the coolant system will have you voiding your lease agreement anyways, you are not going to be fixing this yourself. Not trying to be mean here, but seriously now.......
Old Jul 17, 2011 | 05:35 PM
  #60
LawDog88's Avatar
If I had the cash I would be taking it in, and if the service rep I dealt with last time wasn't being a douche and telling me that they couldn't facilitate me for something that MAY have been their fault..
