Not starting
I marked it before I took it apart. But it only goes on one way at that connection.
The trans mount on the driver's side fender has large holes, looks it would be for an adjustment? When I bolted it back together the mount wasn't in the same location as when I took it apart. I don't see how that could have anything to do with the steering wheel but it's the only thing I can think of that's not the same
If the steering rack was moved while disconnected it doesn’t always line up when you reconnect it to the lower yoke of the intermediate steering shaft, throwing the steering wheel off
A: realign the transmission mounts.
B: check if steering wheel is centred
