Not starting
Old Jun 28, 2022 | 09:17 AM
  #31
flstss's Avatar
Originally Posted by Oldblue
Are you talking about the splines of the upper joint on the intermediate steering shaft ! That might cure your issue
No. When I took it apart to do the shift solenoids, I disconnected the steering shaft at the rack.
I marked it before I took it apart. But it only goes on one way at that connection.
The trans mount on the driver's side fender has large holes, looks it would be for an adjustment? When I bolted it back together the mount wasn't in the same location as when I took it apart. I don't see how that could have anything to do with the steering wheel but it's the only thing I can think of that's not the same
Old Jun 28, 2022 | 09:43 AM
  #32
If the steering rack was moved while disconnected it doesn’t always line up when you reconnect it to the lower yoke of the intermediate steering shaft, throwing the steering wheel off
A: realign the transmission mounts.
B: check if steering wheel is centred
surfer54
Oct 22, 2011 03:39 PM
Jeff®
Oct 16, 2009 07:07 PM
Freightliner
Nov 25, 2008 05:09 PM
nhisfan
Aug 12, 2008 02:33 PM
SoCal4me
Aug 1, 2006 08:26 PM
