Oil leaking into Coolant
Old May 29, 2023 | 10:39 PM
  #111
PulpFriction's Avatar
Originally Posted by tr34
The timing gasket looks fine - is this safe to reuse?
I think so. Not if it's already leaking, of course. But I didn't reuse mine, on the theory that if it leaked it would be a pita to fix. I also gave the seal surface a lot of attention. The valve cover I reused.
Old May 30, 2023 | 11:47 AM
  #112
greg8453's Avatar
Okay, got the timing cover off and reset the balance shaft tensioner. The timing gasket looks fine - is this safe to reuse?
While I'm waiting for a new crankshaft bolt, I might as well buy the ZZP guide. Looks like all I have to do is remove the old guide and install that without touching anything else. I was checking the bolts in the timing chain area and I must've forgotten to torque the lower bolt for that guide too. It was about one turn away from even being hand-tight.
I wouldn't.
Old May 30, 2023 | 12:14 PM
  #113
Neither would I , I didn’t have any luck reusing the FelPro front cover gasket or valve cover gasket, last fall
Old May 31, 2023 | 03:19 PM
  #114
tr34's Avatar
Ordered a new timing gasket. Is it worth it to retime the car while I have the cover off?
Old May 31, 2023 | 03:46 PM
  #115
You will have to to reset the balance shaft chain, and be ready to change the chain if it’s at all streched
Old May 31, 2023 | 04:16 PM
  #116
greg8453's Avatar
If you mean replace then maybe if the chain is stretched or the guides are worn. I would inspect things but as for timing unless it had jumped time it'll be in time still.
Old May 31, 2023 | 05:21 PM
  #117
tr34's Avatar
I reset the balance shaft chain tensioner but the chain tension feels loose. It doesn't look like it's stretched.
I was just wondering to just set the car to TDC and realign the chains back up to the marks in case it moved off a tooth at some point. When I was loosening the crankshaft bolt with an impact, the harmonic balancer turned counter-clockwise maybe a 1/8 or less of a turn. The timing chain for that still feels fine Just trying to be cautious so I don't end up having to take everything apart again.
Old May 31, 2023 | 06:39 PM
  #118
If there is ANY slack between the sprockets the chain needs replacing. I doubt 1/8 turn would jump a tooth.
If you have over 100,000 miles on the chain, I would go ahead and replace the chains, tensioners and guides.
Old May 31, 2023 | 07:21 PM
  #119
tr34's Avatar
I have 7000 miles on the chains and guides. Car is only at 72k miles. I'll try resetting the balance shaft tensioner again just to make sure I didn't screw something up there. For both chains, I shouldn't be able to push in on them at all right?
Old Jun 1, 2023 | 06:36 AM
  #120
Right
