Oil leaking into Coolant
Old Dec 30, 2024 | 03:35 PM
  #201
tr34's Avatar
It sounds like it's coming from the bottom of the engine, I guess one of the rod bearings decided to spin... It sounds just like this video:
I think I'll try pulling the oil pan today to take a look at the rods
Old Dec 30, 2024 | 04:00 PM
  #202
That’s not your car ?
That video has way too much back ground noise to tell much. Heck , I can even hear and see the traffic in the background.
Get a video of your car.
Old Dec 30, 2024 | 08:22 PM
  #203
tr34's Avatar
I got a little ahead of myself and pulled the pan before getting a video, oops. The rods have no vertical play, just a tiny bit of horizontal which I think is fine. I'm guessing it's not a good idea to start the engine with no oil pan, so I'll try to get a video in a day or two once I get it back on
Old Jan 1, 2025 | 02:03 PM
  #204
tr34's Avatar
Okay, I got a video of the ticking here:
It kinda sounds like it's coming from the exhaust area
Old Jan 1, 2025 | 03:01 PM
  #205
Try checking the exhaust manifold bolts. The torque spec is very low,(10 lbs. ft) and twice I've found mine to be loose.
Old Jan 2, 2025 | 04:26 PM
  #206
greg8453's Avatar
When listening for sounds you should do more than just idle. Snap the throttle once and hold it at 3000 rpm for a moment or two.
Old Jan 2, 2025 | 06:43 PM
  #207
tr34's Avatar
I checked the exhaust manifold bolts and everything was tight. I got one more video of it accelerating. The noise only seems to appear on faster accelerations
Old Jan 3, 2025 | 07:54 AM
  #208
PulpFriction's Avatar
One can only guess, but mine is chains. I’d pull the valve cover and look at the front guide.
Old Jan 3, 2025 | 08:03 AM
  #209
Have you looked at the air box bracket?
Old Jan 3, 2025 | 01:06 PM
  #210
tr34's Avatar
I pulled it off in that second video, but it still made the noise. I took off the valve cover last night, and everything looks good with the exception of possibly one rocker arm for the cylinder 3 exhaust. It looks like the bearings are visible in the picture, is this normal for them?
. I'm going to try using a stethoscope today to narrow down where the noise is coming from.
