Oil Pan Gasket
Old Jun 7, 2024 | 07:13 AM
fastsuv's Avatar
The problem with using a gasket to seal two flat surfaces is the gasket has a tendency to slide out between the screws.
Notice the gaskets that are on the engine (timing cover, valve cover, etc) fit into a designed recess or have a metal layer to keep the gasket from deforming.
Also, most modern engines use the oil pan as a structural element for the engine, which might explain why they don't use a gasket on the oil pan. In the old days the oil pan was a stamped steel pan just hanging off the bottom of the engine to hold the oil. The cast aluminum pans add rigidity to the block and help vibration. A very thin silicone layer allows the pan and block to mate together tightly. A gasket would act as an isolating layer, allowing some movement (even if the movement is very small).
Steve
Old Jun 7, 2024 | 08:06 AM
What is wrong with the RTV they use in the factory?
Old Jun 7, 2024 | 08:59 AM
It ain’t rocket science ! Clean the pan mating surface. Clean the lower block mating surface. A thin bead of sealer on the pan surface. Let it “sit” till it dries a little. Carefully install pan. Tighten bolts uniformly and torque to spec.
Old Jun 7, 2024 | 09:21 AM
18 ft lbs
Old Jun 17, 2024 | 08:48 AM
PulpFriction's Avatar
Exactly. The specified product is GM's 12378521 RTV, and you can by a tube for about $12 shipped, but I'm sure any reputable RTV will be fine.
RTV adheres well enough that it's plausible that the pan adds to the block's stiffness. (Easy! I only said plausible, didn't say it's so.) That would be less so if silicone or a gasket were used.
The tricky thing would be to make sure the block mounting surface is oil-free. Easy in the production facility with an inverted engine. Under a car, not so much.
GravesHHR
Feb 29, 2024 03:00 PM
arizonalone
Dec 28, 2022 07:29 AM
SwaintaN
Feb 19, 2014 04:41 PM
Heritage High Roof
Apr 10, 2012 03:48 PM
cohutta20
Jan 10, 2012 09:11 PM
