Overheating
Old Aug 25, 2021 | 02:55 PM
Jim L's Avatar
I have a 2008 HHR LT 2.4 l, it overheats when accelerating or climbing a hill. I've replaced the radiator, cap, water pump, thermostat, and all hoses, I've also replaced the catalytic converter! No oil in coolant, no coolant in oil! Thought maybe the sending unit was faulty, but if it gets to about 230 degrees, it starts acting like it's vapor locking! It seems to cool down some when at idle! Any suggestions?
Old Aug 25, 2021 | 02:59 PM
The fan should come on at about 217F or when the AC compressor is running.
Old Aug 25, 2021 | 03:10 PM
Welcome to the site, perhaps a good burp is in order!
https://www.chevyhhr.net/forums/how-...-system-60614/
Now, I don’t know, so I’ll ask, what coolant did you use? What thermostat? What water pump? Did you replace the balance shaft chain or use the hood tool?
Old Aug 25, 2021 | 10:53 PM
Jim L's Avatar
Dexcool, 180 degree, ac Delco, and used the tool.
Old Aug 26, 2021 | 07:01 AM
And the water pump, plastic impeller or metal?
Is it possible the balance shaft chain isn’t engaged?
Old Aug 26, 2021 | 09:14 AM
Is the AC condenser full of bugs or otherwise clogged?
Old Aug 26, 2021 | 01:43 PM
Lonwane's Avatar
Are you trying to outrun a Hellcat SRT or climbing these hills at 80 MPH?
Old Aug 27, 2021 | 01:59 PM
PulpFriction's Avatar
I’ll second that. If the water pump wasn’t running it wouldn’t cool down much at idle.
Kokomo
Nov 17, 2022 09:38 PM
Jpaulparis
Nov 26, 2015 09:52 AM
cyberwolf009
May 3, 2015 01:51 AM
batsibf
2.4L Performance Tech
14
Apr 26, 2015 11:22 AM
