P0010 problem
P0010 problem
I had code p0010 so I went and had the Cam actuator replaced, had the plugs, and air filter replaced as well since I was there. Also had the oil changed. When I left everything was good. Later that evening, it came back. They were closed, so I went the next morning and they cleared out the code and was good most of the day then it came back again tonight. Not sure what else to do here.
I’ve done the obvious stuff but I’m not going to get worked up about this. I still get about 28 mpg, so I don’t think engine performance is affected. I use my foxwell code reader to clear
the annoying check engine light about every other day. But I know the engine is fine so I don’t lose any sleep over this.
P0010 doesn’t indicate the intake or exhaust, it indicates the VVT solenoids, as you replacing the one, replace the other
https://www.obd-codes.com/p0010
I moved this to it’s own thread
P0010 indicates the intake CIRCUIT has a problem, not necessarily the solenoid. It could be the electrical element in the solenoid but you have replaced that so, look for wires frayed or burned.
If you test the solenoids they should read 8-12 ohms. The connections are control and low ref, both go to the ECM. The cheap ones are known to be problematic.
If anyone has messed with the ECM connectors there is a chance a pin is bent or pushed out the back.
Don't clear codes, it fixes nothing. When the problem no longer exists they will clear themselves.
These are old cars. There can be broken or corroded connectors or wires inside insulation that looks fine. You can check for high resistance in the wires while wiggling them around.
If a solenoid valve isn't working correctly, the engine isn't running optimally, and economy could suffer, and other problems could ensue. Imagine all the trouble that could result from the intake valve opening and closing at the wrong time.
