P0014 after installing new Actuator
At around 280,000 miles, I started getting a P0010 a couple of weeks ago. I had got this in the past at around 140,000 miles and replaced the actuator. About a week ago, I was also getting a P0011 (I had replced this actuator around the same time as the other in the 140K range). I was having some severe intermittent rough idling. I replaced both actuators this morning. The car ran fine afterwards.
This afternoon, I started to get the rough idle again and a P0014 code. Any ideas what is going on?
I am due for an oil change. The last one I replaced a few years ago was bad out of the box.
I will change the oil and see if that improves things. I didn't seem to have any issues getting the connector on but may take it off to make sure the pins aren't bent.
Thanks for the tips. I will let you know what I find.
jayweston
Jul 12, 2014 03:01 PM
djones508
Sep 17, 2013 06:11 PM
