P0014 code and "fix" NEED HELP!
Old 02-03-2016, 02:52 AM
Agpullen's Avatar
I had been getting the check engine light off and on a couple of times and the car wasn't acting weird. I had the local Autozone check the codes and it pulled up the P0014 code. A little searching on here and found it to be the Camshaft Position Solenoid so I replaced both the intake and exhaust making sure I had the correct parts and they were in the correct place (grey in front, black in back). I put the car back together and reconnected the battery, and the car started making a clicking noise that will increase with throttle. I drove it around a little bit and it drove better minus the ticking/clicking noise. The check engine light went away for a few hours and has now returned. Anyone have any idea what might have gone wrong?
2011 HHR 2LT 2.4 ltr
Agpullen is offline
Old 02-03-2016, 03:18 AM
First off you need to download the current CEL code. Assuming that the current code is the same as the p0014 previously can lead one on a wild goose chase.
However you can check a couple of things right off the bat:
- are you sure the MAF sensor on the intake tube was properly plugged back in?
- check the oil level - low oil or OLD oil can also cause a p001x code
whopper is offline
Old 02-03-2016, 03:43 AM
Agpullen's Avatar
I had the codes checked again and it came up as thesam e code and made sure all the plugs were put back correctly, I'll get an oil change and see if that might fix it.
Agpullen is offline
Old 02-03-2016, 08:24 AM
Per this
http://www.obd-codes.com/p0014
Check the wire harness to the solenoids and it could be a faulty new solenoid!
Did you use GM solenoids or inferior aftermarket pieces?
Oldblue is offline
Old 02-03-2016, 11:03 AM
Good points Oldblue.
How long has it been since the last oil change?
whopper is offline
Old 02-03-2016, 11:29 AM
Ticking/clicking noise that goes away upon warming up? Along with P0014?
H'mmmm, Timing chain/guides/tensioner.
donbrew is offline
Old 02-03-2016, 12:48 PM
aradmahogany's Avatar
Gotta go with Ac Delco on those solenoids brother. I replaced mine years ago with zero issues.
aradmahogany is offline
Old 02-05-2016, 03:27 PM
Agpullen's Avatar
I just got the oil changed and it's still knocking. Its not as bad but still there, and I have slight hesitation on the gas as well. Not all the time thou. I'm thinking lifter but I don't know. I'm good with old cars, not computer controled ones.
Agpullen is offline
Old 02-05-2016, 04:35 PM
They are really the same. OBD mean On Board DIAGNOSTIC. Not MAGIC.
donbrew is offline
Old 02-05-2016, 04:57 PM
Agpullen's Avatar
I know its not magic i just hate dealing with all the plugs and sensors and computer stuff. That's why I like my '78 Camaro, it's simple.
Agpullen is offline
Quick Reply: P0014 code and "fix" NEED HELP!
