P0036 P0141 P0054 codes
Hmm, ok, I reread your original post, you changed the downstream o2 sensor it was good for awhile and then again you changed the downstream o2 sensor both times with a Bosch sensor, this indicates that the wires are ok, the Bosch sensor is suspect. Get either a GM original or a Delphi or Denso . Give the connection a squirt of electrical contact cleaner and a dab of dielectric grease and install carefully and ensure the connection is seated firmly .
Okay I don't have an SS. It looks like in the diagram the same wire goes to both upstream and downstream sensors for the heating. I only got a code for the downstream. So I guess everything up to the upstream sensor is good for the heating wire the downstream maybe the issue in The wire or connector? I'll get a different sensor and see if that will work.
choices are:
fuse
wire]
connector
BOSCH sensors suck, that's why they are a dollar cheaper than NGK/NTK
If you follow the lines on the schematic you will see the the relay supplies power to the fuse. therefore power won't go to the sensor if the relay is not energized.
fuse
wire]
connector
Okay, I have the key in the on position and the fuse is energized so I should have power to one of the wires that go to the sensor?
You need to probe the Pk/blk wire ignition on. should get battery. The heater is grounded when engine is running. We can test that later if this is OK.
Okay ignition on power to the fuse the upstream sensor has power to the pink black the downstream sensor no power so there's the problem I'm assuming. I guess I will jump a wire from the pink black on the upstream to the pink black on the downstream to get power to the downstream. Sounds like the right thing to do? Thanks
