P0036 P0141 P0054 codes
Old Jun 10, 2023 | 06:24 PM
greg8453's Avatar
Originally Posted by flstss
Okay ignition on power to the fuse the upstream sensor has power to the pink black the downstream sensor no power so there's the problem I'm assuming. I guess I will jump a wire from the pink black on the upstream to the pink black on the downstream to get power to the downstream. Sounds like the right thing to do? Thanks
You can do a redundant line or we can load test that leg.
Old Jun 10, 2023 | 10:08 PM
flstss's Avatar
Explain please
Old Jun 11, 2023 | 10:11 AM
flstss's Avatar
Okay I got it! The wire pink and black coming out of the connector and then goes into the convoluted tube. There was a break in The wire under the insulation. Insulation was intact but there was a break. Repair and no more c e l
Old Jun 11, 2023 | 10:29 AM
Nice detective work!
Old Jun 11, 2023 | 02:53 PM
greg8453's Avatar
Don't look like we needed to load test that leg. How did you repair it?
Old Jun 11, 2023 | 04:26 PM
  #26
flstss's Avatar
Soldering shrink sleeve
Old Jun 11, 2023 | 06:53 PM
  #27
So you’re a leg up on the wire harness! Great it’s fixed
Old Jun 11, 2023 | 10:47 PM
  #28
greg8453's Avatar
Proper fix. Good job.
mobilebyrd
Mar 24, 2020 06:44 PM
06REDSEDANDELIVERY
Mar 16, 2018 05:10 PM
hvrod
Jan 8, 2018 06:32 AM
ChevyMgr
Jun 20, 2016 12:02 PM
kizzme
Aug 31, 2007 09:53 PM
