P0036 P0141 P0054 codes
Old Jun 9, 2023 | 11:15 AM
Hmm, ok, I reread your original post, you changed the downstream o2 sensor it was good for awhile and then again you changed the downstream o2 sensor both times with a Bosch sensor, this indicates that the wires are ok, the Bosch sensor is suspect. Get either a GM original or a Delphi or Denso . Give the connection a squirt of electrical contact cleaner and a dab of dielectric grease and install carefully and ensure the connection is seated firmly .
Old Jun 9, 2023 | 11:23 AM
Here is the schematic, ignore the HOS1 part I think that is not for SS.
I think the PWR/TRN relay should only be energized in run.
Old Jun 9, 2023 | 11:41 AM
flstss's Avatar
Okay I don't have an SS. It looks like in the diagram the same wire goes to both upstream and downstream sensors for the heating. I only got a code for the downstream. So I guess everything up to the upstream sensor is good for the heating wire the downstream maybe the issue in The wire or connector? I'll get a different sensor and see if that will work.
Old Jun 9, 2023 | 11:44 AM
flstss's Avatar
Should there be power to the sensor from the fuse block fuse 33 when the key is in the run position? When the key is in the run position there is power to the fuse. Just don't know if the engine has to be running in order for power to go to the sensor.
Old Jun 9, 2023 | 01:35 PM
Engine running.
Old Jun 9, 2023 | 02:17 PM
choices are:
fuse
wire]
connector
BOSCH sensors suck, that's why they are a dollar cheaper than NGK/NTK
If you follow the lines on the schematic you will see the the relay supplies power to the fuse. therefore power won't go to the sensor if the relay is not energized.
Old Jun 9, 2023 | 04:03 PM
flstss's Avatar
choices are:
fuse
wire]
connector
Okay, I have the key in the on position and the fuse is energized so I should have power to one of the wires that go to the sensor?
Old Jun 9, 2023 | 05:46 PM
According to the schematic the pink//black wire should be 12 V.
Old Jun 9, 2023 | 05:49 PM
greg8453's Avatar
You need to probe the Pk/blk wire ignition on. should get battery. The heater is grounded when engine is running. We can test that later if this is OK.
Old Jun 10, 2023 | 05:13 PM
flstss's Avatar
Okay ignition on power to the fuse the upstream sensor has power to the pink black the downstream sensor no power so there's the problem I'm assuming. I guess I will jump a wire from the pink black on the upstream to the pink black on the downstream to get power to the downstream. Sounds like the right thing to do? Thanks
