P0172
Pulled VVT solenoids and cleaned then out real good with throttlebody cleaner and used air hose to blow them out dry. Sprayed some more throttlebody cleaner on throttlebody. Didn’t want to start at first then did.
Drive it awhile give the engine a chance to warm up, let the computers do there job. That sort of stuff.
if there’s no air leaks in the intake or exhaust leaks in the flex pipe , the MAF sensor has been cleaned, that pretty much leaves fuel pressure, the hard start could be an indicator of that .
Forgot to say cleared the code or codes. My buddy worked out a deal on a brand new MAF for me to try it out and if that’s it I pay for it. If not he can bring it back. So took a short drive and no light on yet will see in a few again. If it comes back on will put MAF sensor on and let the car idle for awhile and see if it goes off or acts better.
