P0300 p0301 p0302
Old Jul 19, 2018 | 08:22 PM
  #91
And if he did , you’ll need a new ZZP custom intake or I think TTR had one too!
That gasket goop ruined the manifold, honey! I’m gonna just order up a new one!
Old Jul 20, 2018 | 07:33 AM
  #92
DrLoch's Avatar
Originally Posted by donbrew
The intake has 4 O-rings. He must be one of those old farts that puts gasket shellac on everything. Just hope he didn't put any silicone on it
SS - Turbo 2 Liter actually has a metal gasket 12589366.
RJ that thing is really clean inside
Old Jul 20, 2018 | 07:47 AM
  #93
I’m still on the old school side, if you have it apart, change the chains and tensioners and guides.
Old Jul 20, 2018 | 10:43 AM
  #94
Do you have a tracking number, so I can see when it's supposed to get here?
Very generous of you!
Old Jul 20, 2018 | 10:53 AM
  #95
I see! The manifold is metal. I don't know why I was thinking they would be the same.
Shellac on a metal gasket is even dumber. I am assuming it is multi-layer?
Old Jul 20, 2018 | 11:07 AM
  #96
How could I have overlooked the fact that the camshafts have to be removed in order to change the guide seals?!? Closing back up, try again next weekend!
My hope is to remove the timing tensioner, then remove the TTY bolts and carefully pull the phasers away from the camshafts. Then I can remove the camshafts. Gotta figure a way to hold the phasers safely in place. Looks like the rocker arms just sit in there, not attached to anything. New TTY bolts have been ordered from dealer. I'll want to set it at #1 TDC, of course.
I know best practice would be to replace all the timing components, but... If this doesn't fix the oil consumption problem, and the real culprit turns out to be pistons/rings.... I'm gonna be wanting a new engine.
I don't want to put more time/money into this engine... and replacing the seals AND the timing set would take more time than I have in a weekend.
Old Jul 20, 2018 | 11:12 AM
  #97
Memory seems to tell me it is not multi-layer. There are numerous pics in the shell blast tut. https://www.chevyhhr.net/forums/how-...lves-ss-56184/ Hard to tell. The exhaust gasket was definitely multi-layer, I don't think intake was.
Old Jul 20, 2018 | 12:13 PM
  #98
I reread your shell blasting tut. You said then that #4 was leaking to the crankcase, i.e.: rings.
Old Jul 20, 2018 | 12:42 PM
  #99
I'm thinking not rings, because the % of leakage has not changed since then.
Old Jul 20, 2018 | 01:03 PM
  #100
There’s a tool to hold the phasers and keep the timing chain tight
GM-015 GM Ecotec 2.0/2.4 Camshaft Actuator Locking Tool [GM-015] - $185.00 : TechPro Professional Auto Tools
I wish I could afford sending you one of these beauties
https://www.turbotechracing.com/prod...idproduct=5437
