P0300 p0301 p0302
Old May 21, 2018 | 01:29 PM
  #51
DrLoch's Avatar
Plugs don't look that bad, You could try closing up the gap and see if helps at all since you have them out.
Old May 21, 2018 | 01:34 PM
  #52
oil leak in turbo? I still see a difference in the top of plug #1.
Old May 21, 2018 | 02:43 PM
  #53
Cat Man HHR's Avatar
Randy, if you can, take an oil sample and send it out to a lab. That can tell you something. I know there is no base line to compare to, but it might show higher levels of fuel or coolant in the oil.
Old May 21, 2018 | 07:14 PM
  #54
I'm thinking it might be losing oil too quickly/ smoking too much, to be valve guides. If it is the turbo leaking that badly - if it's on the intake side, all cylinders should be misfiring; if it's on the exhaust side, would not cause misfires or fouled plugs.
What other path could oil be reaching the exhaust?
The misfires would probably be injectors in this scenario.
Old May 21, 2018 | 07:18 PM
  #55
Valve guides and valve guide seals, I’ve gotten away with just replacing the valve guide seals on a couple of SBC’s over the years, my sponsor didn’t like an oil cloud smoking race car.
Old May 21, 2018 | 07:20 PM
  #56
So valve guides could suddenly start leaking a lot of oil?
The misfires have been there before the oil loss/smoking.
Is there a way to determine if it's guides/seals?
Old May 21, 2018 | 07:23 PM
  #57
I was young and energized, I just torn the heads off, and changed the seals.
Old May 21, 2018 | 07:27 PM
  #58
You mean like this?
Old May 21, 2018 | 07:29 PM
  #59
That's a good thought, Richie, I'm considering it.
Old May 21, 2018 | 09:28 PM
  #60
Naw, more caffeine driven
