P0449 and p0455
Why not just look at what you can see, that is the only exposed part, the rest is in the body harness under the seats. I don't know what good a wiring diagram is it just tells the endpoints. Usually it is in the connector or nearby it. Make sure somebody didn't try to use the adapter that comes with some replacement valves for 2006-2007 models.
Well i just removed this clown show i found about 3 inch off the vent valve burried in the wire loom... car has been running 20-30 mins now still no light... hopefully just tires and a drive cycle so i can pass NY inspection it will be back on the road!
Two splices in each line , not soldered, was it taped at least , no shrink tubing? Two 1/2 a$$ed jobs done by 1 A$$Hat. Pitiful, just pitiful. This is an example of check the wiring, make sure it’s done right!
Glad you found that, now you can get it tested.
MercyCroft
Oct 18, 2019 12:49 PM
