P0449 and p0455
Old Feb 22, 2022 | 12:02 PM
If the fuse is blown the N.O. EVAP vent valve will remain open = large leak. P0455.
if the fuse is blown the EVAP vent valve won't operate as designed. P0449
Old Feb 22, 2022 | 01:10 PM
PulpFriction's Avatar
Ah! Thank you. Didn’t know it would stay open. Makes sense.
Old Feb 22, 2022 | 03:20 PM
Joe Reed's Avatar
so the fuse is not blown now... however 449 is back... so i think im wire hunting at this point... does anyone have a wiring diagram for this?
Old Feb 22, 2022 | 03:21 PM
Joe Reed's Avatar
nope but the code is back
Old Feb 22, 2022 | 03:38 PM
The EVAP test takes some time and a drive cycle. I suspect the valve is shorting out when activated.
Old Feb 22, 2022 | 03:41 PM
Joe Reed's Avatar
thats what im thinking too... so now i need to hunt down a wiring diagram... bc i have no problems getting 20 feet of wire and just running a brand new pair straight to the ecm
Old Feb 22, 2022 | 04:06 PM
Why not just look at what you can see, that is the only exposed part, the rest is in the body harness under the seats. I don't know what good a wiring diagram is it just tells the endpoints. Usually it is in the connector or nearby it. Make sure somebody didn't try to use the adapter that comes with some replacement valves for 2006-2007 models.
Old Feb 23, 2022 | 09:13 AM
Joe Reed's Avatar
Well i just removed this clown show i found about 3 inch off the vent valve burried in the wire loom... car has been running 20-30 mins now still no light... hopefully just tires and a drive cycle so i can pass NY inspection it will be back on the road!
Old Feb 23, 2022 | 10:05 AM
It looks like somebody spliced a new connector in. That doesn't explain the fried wires.
I believe NY will allow 1 not ready test.
Old Feb 23, 2022 | 10:25 AM
Two splices in each line , not soldered, was it taped at least , no shrink tubing? Two 1/2 a$$ed jobs done by 1 A$$Hat. Pitiful, just pitiful. This is an example of check the wiring, make sure it’s done right!
Glad you found that, now you can get it tested.
MercyCroft
Oct 18, 2019 12:49 PM
alexrckid
Dec 18, 2016 07:47 AM
zachrf
Maintenance and Upkeep
12
Oct 10, 2014 10:09 PM
jwjones
Nov 20, 2013 07:22 AM
