Part connected to 25803946
Old Jun 13, 2021 | 05:28 PM
triskalion's Avatar
I was looking through the manual, but it did not seem to have any with the label EXH.
Old Jun 13, 2021 | 06:13 PM
Not seeing it either
https://fuse-box.info/chevrolet/chev...uses-and-relay
Old Jun 13, 2021 | 08:47 PM
#33 underhood.
Old Jun 13, 2021 | 09:35 PM
Ah, the emissions fuse#33
Old Jun 14, 2021 | 04:08 PM
triskalion's Avatar
Pulled, checked, and didn't notice anything strange with it. I swapped it for the spare fuse that is in the box lid and started car. Same Check Engine Light.
Old Jun 14, 2021 | 04:55 PM
Refresh my memory, what is that code?
Old Jun 14, 2021 | 04:58 PM
triskalion's Avatar
P0131 and P0420. They seem to be the first Exhaust sensor and then the catalytic system. From searching it seems the first code may cause the second code
Old Jun 14, 2021 | 05:00 PM
Precisely
Take care of the P0131 code and most likely you’ll fix the second code.
Old Jun 14, 2021 | 05:19 PM
p0131 is low voltage to O2 sensor #1. That means check the wires/connectors, if they are all good replace the #1 sensor.
It means the voltage is less than 50 mV; in other words: disconnected from voltage supply. Not unusual for the wires to get dislodged and burned on the exhaust pipe, or water in the connector.
RevPaul
Mid Central
Nov 6, 2021 12:17 AM
JTinVT
Oct 19, 2010 11:31 AM
NEXTIMAGE
North Pacific
Apr 5, 2008 03:53 PM
PhoS
Jan 26, 2008 04:16 PM
TomsHHR
North Central
0
Feb 26, 2006 07:47 AM
