more water on drivers side
Old Oct 17, 2010 | 07:01 PM
JTinVT's Avatar
I've had my 2009 back to the dealer twice for water leaks onto the drivers side floor. It rained yesterday and the floor was wet again. There was only a little water this time but it was still wet.
The first time I had it back they sealed around where the wires run from the door to the body. The last time they removed some foam that was between a joint and siliconed the body plug just behind the hood release lever.
I've pulled the panels off of the passenger side and there's no trace of water.
The service advisors have been good. I don't want to be a jerk about it but I'm getting a little pissed.
Should there be that much water running down that area? Has anyone else had any continuing water problems? Siliconing body plugs seems like just a way to cover up the real problem. Does anybody have any suggestions?. Thanks for any ideas.
Old Oct 17, 2010 | 07:32 PM
urbexHHR's Avatar
Do you have a sunroof? Could be the drain tubes. Otherwise it could be the butchyl patch. Or does that only make it leak on the passenger side?
Old Oct 18, 2010 | 12:52 AM
Eric-
GM re-designed that area & IIRC ? 2007 was last to use the patch.
Newer ones do NOT have it..
JTinVT-
Perhaps you can have a friend hose down the HHR front & roof, with you inside & keep looking for an entry point....
Old Oct 18, 2010 | 01:30 AM
If you can narrow it down to a general area, and if room permits, apply baby powder in the general area (you can "puff" the plastic can it comes in, to apply it) - this way you will be able to see where the leak is originating, as it will create trails thru the powder that are very easy to see. I used this trick successfully in the past to track a water leak in the trunk of my old Mazda 626 after the dealer could not find it.
and it makes your car smell like a baby's bottom - that may or may not be a good thing!!! LOL
Old Oct 19, 2010 | 08:35 AM
JTinVT's Avatar
I don't have a sun roof. It seems to leak only when driven. I have had a hose running on it for quite a while. I also sprayed in the wheel well. I think it must come in primarily when the car is driven. I am going to do the baby powder or maybe by a can of spray foot powder.
Stopping the water from getting in is one thing. My concern now is if there should there be that much water getting into that area. Sealing with silicone only hides the real problem.
For now I guess I will powder my baby and try to keep the carpet dry.
Old Oct 19, 2010 | 11:31 AM
Yeah give it a try - and best of luck. Never thought of the spray foot powder - might work well. As long as it doesn't leave the car smelling of "FEET"?????
Navy Chief
Aug 22, 2016 12:55 PM
Gator
Apr 21, 2016 07:21 AM
greyholl
Jul 4, 2013 09:45 AM
DrTrapper
Jan 3, 2012 07:43 PM
stanvalp
Apr 26, 2011 07:36 PM
