For people that change outer seal on the transmission
Old Apr 3, 2019 | 08:10 PM
hurst2001's Avatar
Got a 2007 2lt automatic and my seal where the axle goes in the trans is weeping on the passenger side .. So my question is this side has that stub shaft ? if so does axle spline go over it ? I just want to replace the outer seal to stop the leak ... This is the first time playing with it and I really don’t want to be playing with the stub at all .. So I know there people here that have done it before so just lookin at inputs and what to look out for ... thanks
Old Apr 3, 2019 | 08:39 PM
When I pulled my axles , the stub shaft stayed in the transaxle, looks like the passenger side
https://www.chevyhhr.net/forums/driv...l-issue-60751/
Old Apr 3, 2019 | 08:47 PM
Yes, passenger side it usually stays on the axle and you have to remove it to put it on the new axle. I had some success using a muffler clamp and a hammer, there is a post with pics somewhere on here.
Here is one with the correct tools. https://www.chevyhhr.net/forums/driv...l-issue-60751/
oops, that's the same as Oldblue linked.
Old Apr 3, 2019 | 09:06 PM
hurst2001's Avatar
Originally Posted by donbrew
Yes, passenger side it usually stays on the axle and you have to remove it to put it on the new axle. I had some success using a muffler clamp and a hammer, there is aa post with pics somewhere on here.
thanks don can you pry bar the axle out ? I mean I’m asking because I’m not doing the job because bad back problems .. just letting the shop do it ..
Old Apr 3, 2019 | 09:24 PM
One of those BF screwdrivers with a bent tip is the perfect tool but anything that fits will do it. Slide hammer is the right way; Don't pull on the axle, that will mess the tri-pot up. You have to get between the tri-pot and the trans housing.
Old Apr 4, 2019 | 09:38 AM
I used two flat pry bars , one from the top one from the bottom, the axle popped right out, without the stub shaft.
HeavyHook
Drivetrain (Excluding Engine)
10
Sep 5, 2018 07:36 PM
gio89kid
Jan 1, 2018 05:50 PM
Twistedtat
Nov 24, 2014 01:50 PM
DaytonaBlueMetallic
Dec 1, 2013 08:38 PM
1970judge
Mods - Exterior
Jul 4, 2011 04:25 PM
