Pesky Oil Leak 07 2.4
Old Dec 2, 2021 | 07:35 PM
Threads merged.
I think this is the second report of this type of leak, to my memory. Yes, it is dreaded because it's a difficult repair.
But donbrew is correct, it's not oil under pressure, so it will only seep a small amount while the engine is running, perhaps a short time after shutdown. I would give the cleaning and resealing in place a try.
Old Jul 21, 2022 | 12:39 PM
MN Murph's Avatar
Oil pressure sensor?
Originally Posted by Oldblue
Then there was the oil pressure sensor.
What did you do about it, i think i have that issue.
Old Jul 21, 2022 | 02:30 PM
I replaced the sensor
https://www.chevyhhr.net/forums/how-...ng-unit-57962/
Old Jul 21, 2022 | 03:39 PM
PulpFriction's Avatar
Originally Posted by teepee2
no because of the dye it illumintates under black light so i know its engine oil. I'm thinking its the oil pan leaking.
Huh. I think you’re saying transmission fluid glows under black light. In every case? I didn’t know that.
I do know some a/c refrigerant has lubricant that is seasoned with fluorescent dye. Maybe they all are, IDK.
Old Sep 24, 2022 | 11:43 PM
Lee3333's Avatar
My 2006 has had an oil leak for a while Changed the valve cover gasket, which was so old it was brittle Still a small leak Used dye and nothing Then noticed that the oil is dripping from the drain plug in the oil pan
Is this common? We loosened the bolt a little and applied some silicone seal and it has pretty much stopped. Hopefully the worn threads are on the drain plug and not the oil pan...fingers crossed
Old Sep 25, 2022 | 06:51 AM
  #26
Oil pan plug should only be torqued to 15 ft lbs there is a gasket on the bolt.
Old Sep 25, 2022 | 09:45 AM
  #27
You are "supposed" to change the gasket every change.
Old Sep 26, 2022 | 03:37 PM
  #28
Lee3333's Avatar
Do you prefer the rubber or copper crush gasket?
Old Sep 26, 2022 | 03:55 PM
  #29
Lonwane's Avatar
What's the OEM part?
That's what I prefer.
Old Sep 26, 2022 | 05:21 PM
  #30
Here's the brand new take-off from my LHU. It's a rubber-like material.
