"Phantom" battery drain
Old Nov 9, 2019 | 02:49 AM
  #41
Cat Man HHR's Avatar
Here is a short video on checking for a parasitic drain.
Old Nov 9, 2019 | 09:41 AM
  #42
Charts are good, but the formula is handy; which is why I used "draw" when talking volts in FMG's thread that Blue_SS took issue with.
AND
An ammeter works by inserting a known resistance "bus bar" into the circuit then measures the voltage V/R=I
Old Nov 9, 2019 | 02:32 PM
  #43
Don
After looking at the Amp draw videos your post #2 now makes sense.
I wish the GM chart had said Amperage draw instead of parasitic load.
Yes the smaller picture does show checking Amps with a battery cutoff switch in the circuit.
The way you show it after hooking up the Amp gauge, you then must pull fuses one by one. Or do you replace a fuse one by one back into the circuit to see the value given.
Checking voltage drop across a fuse and the using the charts I gave a link to will tell the Amperage of that circuit with out using the stand alone tool I posted, or using the method shown.
I have a habit of quickly looking at times, I should slow down.
One thing I did pickup was that wait till the computers boot up fully before taking readings.
Thanks for your input on this.
Old Nov 9, 2019 | 02:52 PM
  #44
The "disconnect tool" is a bus bar (dual purpose).
Old Nov 9, 2019 | 04:35 PM
  #45
I understand that.
Nomenclature is a wonderful thing.
Old Mar 3, 2020 | 11:06 PM
  #46
Zachary Morgan's Avatar
Hey, if you haven't been able to find the drain, try to use a test light between the negative post of battery and ground after you have allowed the computer to go to sleep and then go through each fuse until the light dims. It's called a parasitic draw test and while it's a fairly routine test the issue I ran into with the hhr for the first time was that the ECU had to go to sleep before I could get an accurate result.
Old Mar 4, 2020 | 08:20 AM
  #47
You mean the RAP timed out or stopped when you open the drivers door?
Cat Man HHR
May 26, 2019 09:00 AM
fdv101
Aug 1, 2017 06:43 PM
riceman
Jul 4, 2015 06:02 PM
jack burniston
Oct 6, 2013 07:17 PM
Sparky21440
Mar 26, 2011 08:41 PM
