Question on A/C growl/whine
Old Sep 30, 2008 | 03:26 PM
KYRVNUT's Avatar
AC now 'cool', not 'cold' after compressor was replaced
Hello...
My 2006 HHR with ~4200 miles had the noisy AC compressor noted in this discussion thread.
The dealer replaced the compressor the end of last week. The noise is now gone. However, the unit now blows cool air, not cold. I took it back today and the dealer said everything is "normal". He said it was fully charged and blowing ~40 degrees. If it is 40 degrees now, then it must have been 10 degrees below zero before. :-)
I did see in this post or another one, that someone mentioned the noisy compressor may have been related to the AC system being overcharged. So I don't know if this was the case on mine and I was just spoiled have really cold air before.
Has anyone else experienced this after having their compressor replaced?
Thank you,
David
Old Sep 30, 2008 | 03:47 PM
ChevyMgr's Avatar
If the system is overcharged with freon it will not cool as well and normally will not contribute to noise. Too much compressor oil will also cause insufficient cooling.
Old Sep 30, 2008 | 04:59 PM
Firewatcher's Avatar
I had mine repaired in 2006 under the TSB. Never had a problem after that.
Bigpatshhr
Feb 26, 2014 01:07 PM
Bigpatshhr
Nov 1, 2013 04:30 PM
solman98
Jul 18, 2012 05:30 PM
alexrckid
Jul 14, 2012 10:25 AM
dustymulette
Feb 5, 2010 02:53 PM
