Quick Question Regarding Wheel Studs
Hello! So I just replaced the front brake rotors and pads and was able to take my tire off just fine to do so. However, when I tried to put it back on, I realized the lug nuts wont go on all the way. I tried buying fresh new lug nuts but to no avail. Would it be better for me to just replace the wheel studs and if so, can I remove the old one with a hammer and then insert a new one in its place? I'm new to doing car repairs on my own and want to make sure I'm doing everything correctly. Thanks in advance to all who respond!
I'm not sure if it's because of a wrong rotor, never thought of that though. (This is for my passenger side, I was able to replace the driver side rotor just fine with no lug nut issues or anything). I think the wheel studs may be worn out.
I don't recommend removing them with a hammer because you can mess the bearings up. You probably can borrow a tool from Autozone/Advance/etc that will press them out and in.
As a last resort you can knock them out and use a lug nut and washer to press them in.
dozol22
14
Nov 20, 2011 06:10 PM
