Radiator fan not working 2006 hhr lt
Old Jun 7, 2019 | 01:21 PM
Roy Nettleton Jr's Avatar
Thank you I will next payday as of now I just going to run a toggle switch and jumper to run fan for a week thank you all so much
Old Jun 7, 2019 | 01:25 PM
Cat Man HHR's Avatar
If he broke that off, don't you think the freon leaked out ?
Or it was broken before the problem was found and it never had any left in the system ?
Old Jun 7, 2019 | 01:29 PM
I would think if you don't use the AC the fan would work as it should.
Old Jun 7, 2019 | 03:17 PM
A. the pic of a new part does not seem to have external threads
B. I don't know how the AC would function without it
C. Schraeder valve, no leak, internal threads
D. check relay #50 fuse #40 underhood, Is there power at the relay, is the relay being triggered, etc?
E. The fan might not run with no input from that component, not sure because it inputs to the ECM which controls the fan
F. depending on manufacture date there may be a diode in line in the jumper harness 15 cm from the ground point on the left front of the engine; Been known to malfunction.
Old Jun 7, 2019 | 03:54 PM
Don don't know where you going with this ?
The broken part shown is the nipple that's part of the main hard line manifold that connects to the compressor.
If you look at the picture you can see a green stain. That to me means someone put a dye in the system to look for leaks at some point.
The new part shown will have internal threads that will screw onto the nipple that would have the Schrader valve in it.
Let's see what the OP comes back with instead of chasing a ghost.
Old Jun 7, 2019 | 04:31 PM
OK, on fifth look, I see that the entire nipple from the AC is still attached to the sensor. I can now see the butt end of the schraeder. The AC has no refrigerant in it, unless a new line and sensor was installed but not plugged in.
I guess they found the leak.
Ric
Maintenance and Upkeep
7
Dec 12, 2018 10:18 PM
ToniBob
Mar 21, 2017 09:46 AM
Teamecotec
Mar 6, 2017 08:19 PM
RedTurboSS
Mar 16, 2014 08:22 PM
PrairieHHR
Jun 23, 2011 04:12 PM
