Radiator Filler Neck ⚠️ Warning ⚠️
Old May 20, 2023 | 07:15 PM
planetrj's Avatar
Stop, my sides are hurting!
Thanks Oldblue, I never saw the wishlist button!
😂😂😂 boy, rough crowd! Lol
I actually wrote the first post with the oh-so reliable talk to text, and looking back at it, I can see how there was quite the mockery opt-ed, left wide open there. Thanks for the laffs! 👍
Old May 20, 2023 | 07:22 PM
I edited my post, with a link to what I just ordered!
Old May 21, 2023 | 05:20 AM
planetrj's Avatar
RJ, I wish I could have waited for one of these back then, but it's my daily driver. I just ordered this one, should be here this month. Others are a little less, but wouldn't be here until next month.
https://www.ebay.com/itm/314109425419
Excellent! Just so I can get back on the road quickly, I ordered the Dorman part (plastic), but I’m going to order this one as well, and swap out as soon as it arrives. Thanks a million for that link!
Old May 21, 2023 | 08:49 AM
PulpFriction's Avatar
The threads on my pressure cap tee were poorly matched, making getting the cap on correctly difficult from day one, so I think it was a sloppy vendor. That could also mean defects in material, which could lead to the crumbling. I collected a tee with better threads from a boneyard. Seems solid. Haven’t used it yet, because the original is holding up well enough.
I’m guessing the material was a composite, a blend of nylon reinforced with fiberglass, or something of the sort. The crumbling could be explained by an improper blend locally, with too much glass and not enough resin. One incident should not lead to a panic to replace all these parts, but I do appreciate hearing about this and will keep my eye on it.
Old May 21, 2023 | 09:33 AM
I did warn you back in Sept 2020
Old May 21, 2023 | 09:36 PM
J W Davis's Avatar
Thanks Steve, I do remember your warning about this part from 2020 but it had slipped my mind. I just ordered a new metal one from the link to E Bay just in case.
Old May 22, 2023 | 06:47 AM
Use SS gear clamps on the rad hoses
Old May 22, 2023 | 07:30 AM
That is StainlessSteel, nor HHR SS specific clamps. Somebody will ask/complain.
Old May 22, 2023 | 12:25 PM
Snoopy's Avatar
Originally Posted by donbrew
A tool made for the exact purpose!!! Who knew?
I would have used a stick with marks every sixteenth inch on it, I wish they would sell things like that pre made.
Donbrew.... I did the same as you and I had a draftsman's tri-scale I used. And one day killing time, I was walking around Harbor Freight and noticed they had a SS Digital 6 inch caliper, reading in inches and mm for $15. It also measured outside and inside diameters. I thought what the H$$$ and bought it. Just a little info for others. Oh, and checking the accuracy is within .0015 but can be reset to zero. I have a set of brass cert. blocks.
Old May 22, 2023 | 12:44 PM
I bought one like this on sale at HF 10 or 12 years ago for $9.99 work great for my measuring needs
