Random Stalling Issue
Old Jan 20, 2017 | 01:29 PM
The SDM controls the seatbelts and airbags, the airbag warnings would be active.
#33 is power for the O2 sensors IIRC.
It could be the run/crank relay, that should make maliuhhr happy.
Old Jan 21, 2017 | 01:22 PM
wellsmd's Avatar
The car only stalls out, or misses and sputters when all the way warmed up, could this affect weather it's a relay, fuse, wire or anything else?
Old Jan 21, 2017 | 02:11 PM
I'm thinking a fuel pump issue either loose wires or ground or faulty pump. Now there could also be other problems, you said the spark plugs aren't that old but what plugs are in the HHR AC Delco's 41-103 iridium plugs ?
Old Jan 21, 2017 | 02:32 PM
wellsmd's Avatar
I'm pretty sure, I now they're AC Delco spark plugs for sure. It's been at least 2-3 years since they were replaced.
Old Jan 21, 2017 | 04:17 PM
Sounding a lot like fuel pump.
Old Jan 21, 2017 | 06:06 PM
In post five they aren't that old!? So, maybe swap them out .
Old Jan 26, 2017 | 09:19 PM
alshhr's Avatar
Originally Posted by wellsmd
I have a 2006 Chevy HHR, with a 2.2L Ectotec 4 cylinder engine. For a month and a half now, the car has had a stalling out issue.
It mainly occurs in the morning, right before work, when the engine is warmed up, and idling in park. I have had the issue occur, later in the day too, and also while in drive and idling.
I have been to three different service shops, including a local Chevy dealer. The first diagnosis at the Chevy dealer, was a loose oil cap. This turned out to be false. The next diagnosis was the throttle body. I had the throttle body cleaned, and the mass airflow censor cleaned too, as they were both dirty. The car still stalled out again within a few days.
I have also replaced the battery, and starter during this process. The car is still stalling out, it did it again this morning.
I also ran Lucas Fuel injector through the gas tank one time. I don't know what to do next. Fuel pump and filter setup? Fuel injectors? CO2 censors? EGR Valve? Map Censor? Looking for sugestions and help here. Please and thank you in advance to anyone who can help. Also the check engine light has not come on, and the vehicle always starts right back up.
hope I am doing this right.............check reply#17................
Old Jan 27, 2017 | 04:15 PM
alshhr's Avatar
check ignition module..............cured the same problem in a 2006 buick allure after very reliable tracked it to down.
max69power
Oct 7, 2012 09:57 PM
chrishicks
Nov 3, 2011 11:59 AM
1970judge
Sep 9, 2011 04:14 PM
Alzonie
Aug 26, 2009 03:30 PM
Pretzel
Jun 30, 2007 11:37 AM
