rear right wheel seized
hello,
new problem today with my 2010 hhr, so yesterday it ran great and drove 2 hours no problem to my job, then today I come out to 7 degree temps and start it up and try to go in reverse out of my drive and notice my rear right wheel is seized and won't turn. The parking brake wasn't on and I engaged it and disengaged it to make sure it wasnt. I jacked that wheel up and it is stuck, won't budge.
what is this and why did it happen suddenly after driving fine and then sitting in my drive? seized bearing, or did Jack frost freeze my wheel last night?
it didn't get above 20 degrees today , but idk what or how the cold weather could influence this to happen. I've had bad bearings in vehicles that still turned but never a seized bearing that froze my wheel.
no it was more of a freezing rain at night, there was no real snow accumulation. I probably misspoke about the snow, as it was just a dusting.
Is there a possibility something is frozen and I could use a heat gun to thaw the wheel assembly?
The only place a freeze would make for problems is the shoes freezing to the drum. Pretty sure the hub gave up. Walk up behind the car look at the tires if they are canted outward it is def the hub.
I had this happen to a Pontiac 6000 back in the early 80's.
I went out to lunch from work and the car kept trying to spin the back end around. A motorist behind me told me my left rear wheel wasn't turning. The roads were snow covered and the wheel was just sliding. It had snowed the night before and I had driven through some deep snow that morning going to work. I think the brake heat melted the snow packed around the rear wheel, and then the water froze the shoes to the drum. I found a parking lot with a spot where there was no snow and went forward and back several times before it broke loose with a loud bang.
Steve
Steve
Silverfox
Maintenance and Upkeep
10
Dec 18, 2012 12:17 PM
