Rusty fuel lines
Old Feb 15, 2020 | 11:00 PM
mister hhr's Avatar
Rusty fuel lines
2011 hhr fuel line repair how big of a job is it ? You can smell gas from drivers side rear wheel area
Old Feb 16, 2020 | 05:48 AM
You should replace both fuel and vapor lines. They both run through there and rust is common in that area.
Old Feb 16, 2020 | 07:18 AM
Not a bad job ,
https://www.chevyhhr.net/forums/how-...follies-62310/
Old Feb 16, 2020 | 08:06 AM
Cat Man HHR's Avatar
Here's the replacement Nylon tube kit.
This one goes half way, You don't have change the complete set of tubing if you don't want to.
https://www.inlinetube.com/products/nfr0001
Here is the full lenght kit.
https://www.inlinetube.com/products/nfr0019
Old Feb 16, 2020 | 08:27 AM
But while you can just do half the job, why risk leaks further up the pipes as you have to remove them from the clamps to make room for the tubing cutter, and mine had a pinhole up at the second mount clip from the engine , it would not have been covered with the half set.
Old Feb 16, 2020 | 08:34 AM
That's why I listed both kits " You don't have change the complete set of tubing if you don't want to."
An option for the owner. Maybe lack of funds ?
Old Feb 16, 2020 | 08:41 AM
I’m pointing out a potential problem, from experience, if I had only ordered the half kit, I would be waiting for the whole kit because of the leak up front. That’s all , just my observation, from replacing the lines on Oldblue and the BlackSwan.
you have to ask yourself, “Do I feel lucky? Well, do I?”
fastsuv
Dec 22, 2019 03:26 PM
QuickDrawMcGraw
GM Recall Campaigns
25
May 9, 2019 09:48 PM
SnoopHHR
Oct 14, 2018 05:46 AM
Oldblue
Mar 14, 2018 09:41 AM
Grizzly old man
Maintenance and Upkeep
28
Nov 13, 2015 12:16 AM
