Recommended Motor Oil - I Should Know This
Almost all of the full or part syn are Dexos. 2009-2010 they started including the Dexos recommendation on the oil cap. They also changed the ATF recommendation to Dexron VI, which is a synthetic.
Look at the front cover crankshaft seal, the valve cover, the oil pressure sensor and the oil filter cap area for oil .
I also suggest have a look at the throttle body , oil can get sucked out of the PCV hose down to the rubber elbow at the throttle body.
Fueluser
Maintenance and Upkeep
25
Mar 29, 2019 09:22 PM
