Recommended replacement motor and transmission mounts?
Save the driver’s side transmission mount for another day! I’ve changed 1 in 15 years and it didn’t make any difference. That rear mount only has the one bolt thru it I use a long 1/2 drive extension and 18 mm socket and 1/2 drive ratchet then the 3 bolts up from under the sub frame, I use a 15 mm socket and 1/2 drive ratchet .
There is a "IMPORTANT" note in the service manual "the front and rear transmission mounts must be allowed to settle with the through bolts loosened.".
There is a procedure for balancing the mounts, the book seems to think it is an important step.
Basically loosen all mounts then re torque them in this order> transaxle mount (the one under the fuse box), the engine mount, remove jack to let it settle the raise it back up, rear mount front mount.
