remote starter quit working
Old Feb 23, 2008 | 09:39 PM
prod's Avatar
You may have had an intermittent trouble code. Could have been caused by bad fuel or leaving the gas cap loose or a dozen other things. Anything that activates the engine trouble light will cause the remote start to stop working. If the problem goes away, the codes are cleared after driving for a while.
Old Feb 24, 2008 | 02:14 PM
GCarp's Avatar
If its still under warranty, I would let them change out the parts (assuming they already ordered them). If its intermittent now, it may be a problem later after the warranty runs out.
Old Feb 29, 2008 | 12:12 AM
Originally Posted by denny
Would you just monitor the situation and see if it reoccurs or would you take it into the dealer? Sometimes leaving things alone is the best option...
I would suggest taking it in to get fixed. Mine had the "Key stuck in ignition" problem (for one day), went to dealer to "inform" them of the problem and didn't get it fixed then. Several months later, while on vacation, the same problem occured and would not fix itself like it did the first time. I had to locate the nearest dealer and drop it off on a Sunday.
Old Dec 31, 2008 | 12:27 PM
HHRFORMP's Avatar
Did You Ever Take The Car To The Dealer ?
Just wondering what happened, I am having the same issue
THANKS
mIKE
Old Dec 31, 2008 | 12:48 PM
the_shmoo's Avatar
Check out this thread by HHRFORMP
Cruise.remote Start And Door Locks
Keith
jdavid
Nov 11, 2014 06:09 AM
CarlsSS
Nov 19, 2011 01:42 AM
mo650chopper
Aug 4, 2011 12:39 AM
pjtshhr
Jan 31, 2011 07:48 PM
dav68camaro
Sep 4, 2010 11:54 PM
