Replacement Battery for HHR
Old Jun 4, 2010 | 09:06 AM
tucsondivots's Avatar
The battery in my 2006 HHR is not 4 years old and it is time to replace it before the hot Arizona sun leaves me stranded somewhere.
I have searched the battery threads but did not see any definitive answer on replacement HHR batteries. The last I checked, Autozone, Checker, etc did not have direct replacements. I guess that is due to the vent required since it is located inside the car?
What has everyone been doing as far as replacements? Should I go back to a dealership?
Old Jun 4, 2010 | 09:43 AM
BlackScreaminMachine's Avatar
This is what I found @ Autozone.
http://www.autozone.com/autozone/cat...&parentId=74-0
Part Number: 90-DLG
Warranty:
8 YR Notes: *** 600 cold cranking Amps (750 cranking Amps) *** 100 reserve minutes. -> 3 year free replacement <- Battery is vented to outside of vehicle. Labor intensive installation, 45 minute installation. Located in rear.
Old Jun 4, 2010 | 11:33 AM
Thanks. Turns out none of the Autozones in Arizona have it in stock but the Chevy dealership here in Tucson has it for the same price ($99.95 + $12 core).
Old Jun 4, 2010 | 12:05 PM
BlackknighT's Avatar
Gold-Duralast / Battery
For your 2009 Chevrolet HHR 2.2L Flex Fuel DOHC 4cyl
Price:$99.99
Core*Core value is the used part that manufacturers use for rebuilding. AutoZone charges the core value to customers because manufacturers include it in their prices. When you return your core to AutoZone, we'll refund your core charge.: $12.00
Total:$111.99AVAILABILITY: STORE PICK UPNOT AVAILABLENormally stocked at your local store. SHIP TO HOMEAVAILABLEShips within 2 business days.
Part Number: 90-DLG
Weight: 32.0 lbs
Warranty: 8 YR
CCA: 600
Reserve Capacity: 100 min.
Free Replacement Warranty: 3 years
Prorated Warranty: 8 years
Right Or Left Hand Positive: Right hand positive
Post Location: Top post
Length: 9.5625 in.
Width: 6.9375 in.
Height: 6.9375 in.
Voltage: 12V
Weight: 34.0 lb.
Automotive battery application: Automobile
Shipping Information: Overnight and Two Day shipping are not available for PO Box, APO/FPO/DPO or US Territory addresses.
Features & Benefits
Duralast Gold has AutoZone's highest cold cranking Amps and reserve capacity ratings per group size. Duralast Gold is designed to meet or exceed your vehicle's original specifications. The perfect choice for harsh conditions or high mileage vehicles!
Old Jun 4, 2010 | 12:10 PM
urbexHHR's Avatar
Me personally I like AC Delco batteries. The one in my truck lasted 7 years, and the one in my Lumina was original, and died after 8 years. The one I replaced in the Lumina with only lasted about 3 years, and it's Parts Master.
I know other brands are good, but when a battery that only should last 5 years goes 7 or 8, that's good!
Old Jun 4, 2010 | 12:27 PM
bad03xtreme's Avatar
I like Optima's but they are pricey..
Old Jun 4, 2010 | 03:52 PM
Snoopy's Avatar
I have not needed a battery yet. But I have been shopping because I'm going on 5 years with the OEM Delco.
I have kind of narrowed it down to the WalMart Max 47 (mostly do to a Consumers report of a top rating). It's only $77.00 and a direct replacement ......even with the purge tube.
I believe Costco's house brand is made by the same people. Forgot the price, however.
Oh, for what it is worth.....the Duralast IS rated slightly higher, but it needs to be in the "Gold" range of Duralast. The "regular" Duralasts where near the bottom. The Diehards, almost universally, are rated the best........but are 2 to 3 times the cost of the next closest competitor.
Old Jun 4, 2010 | 07:47 PM
I went with the Delco 90-6YR, same as the OEM. The original is over 4 years old and the 105 degree to 110 degree temps we have now will likely do it in this year -- so I am taking a preventive step and replacing it.
Old Jun 4, 2010 | 08:03 PM
NAPA lists this-
Qty Battery - NAPA Legend International
Product Line: NAPA Batteries
Part Number: BAT 7590
Price: Price
Core
Unit
104.00
5.00
Each
Availability: Available Now
Features & Benefits Maintenance-Free Design Means No Adding Water. Premium Starting Power For Professional Performance.
Features and Benefits PDF
Warranty 75 Months/18 Months Free Replacement
Warranty PDF
Attributes Battery BCI # : 90
Battery CA @ 32 Degrees F : 745
Battery CCA @ 0 Degrees F : 600
Battery Height : 6 7/8"
Battery Length : 9 9/16"
Battery Posts Type : Top Post
Battery Reserve Capacity : 90
Battery Voltage : 12 Volt
Battery Weight : 33.5 lbs
Battery Width : 6 7/8"
Wet or Dry : Wet
Material Safety Data Sheet Lead Acid Battery Wet, Filled with Acid
Application Information: 2009 Chevrolet HHR
Comments: Battery Gasses May Need To Be Vented to Outside;OE Exact Fit Replacement;75 Month Warranty;595 CCA
Per Car Qty: 1
Old Jun 5, 2010 | 10:41 PM
I put in the OEM Delco 90-6YR today in my wife's 2006 LT. The old battery looked like brand new but the concern about the desert heat and being 4+ years old made it seem like the right decision.
The install was a breeze. You have to take a lot of stuff out to get to it but because it is not in the engine compartment everything is clean and nothing is corroded due to heat.
kornellred
Maintenance and Upkeep
43
Mar 5, 2014 11:26 PM
hhrumadbruh
Oct 1, 2013 06:32 AM
RICK167448
54
Nov 4, 2012 07:02 AM
longhornss
Feb 27, 2009 01:15 PM
adamlowery
Nov 18, 2005 02:04 PM
