replacing lower control arm
Old Aug 1, 2010 | 08:54 AM
06SILVERLT's Avatar
hey does anyone know the torque spec of the lower control arm bolts and ball joint bolts?
Old Aug 1, 2010 | 10:21 AM
According to the 2006 service manual pdf.....
Ball joint to control arm nut and bolts. 50 lb ft
Ball joint to steering knuckle (First pass) 37 lb ft Reverse 3/4 turn
(second pass) 37 lb ft +30 degrees
Control arm to front frame bolts 41 lb ft
Control arm to rear frame bolts 74 lb ft +180 degrees
There's a link to these service manuals somewhere on this forum
Old Aug 1, 2010 | 10:36 AM
06SILVERLT's Avatar
i have a control arm with ball joint already on it
Old Aug 1, 2010 | 10:45 AM
So you will be attaching ball joint to the steering knuckle and control arm to frame, no?
Old Aug 1, 2010 | 11:02 AM
06SILVERLT's Avatar
i'll be attaching ball joint to looks like strut and arm to frame
Old Aug 1, 2010 | 11:33 AM
It's the steering knuckle (which the strut is also attached to) Maybe it looks like it's part of the strut when it's all assembled? Those are all the torque specs given in the service manual.
Old Aug 1, 2010 | 12:11 PM
06SILVERLT's Avatar
thank you sr
whopper
"How To" Tutorial Library
179
Jan 1, 2026 07:42 PM
R CA HHR
37
Aug 6, 2019 08:15 AM
budzone
18
Aug 13, 2016 09:17 AM
steveandbelinda
Feb 4, 2013 10:40 AM
06SILVERLT
Mar 10, 2010 07:35 PM
